LCD Projectors
21 Dec 2005
Aberystwyth, UK
Hi,
I've been tasked to find a permanantly mounted LCD projector for my company, basically I'm looking for something that will be used almost exclusivley for powerpoint, so doesn't need to be uber fantastic, but needs to do the job, with a ceiling mount.
I currently know absolutley nothing about LCD projectors, but I'm looking for a lower-spec one, and would appreciate any advice / suggestions on what to be looking for - I don't have a budget as yet, but it isn't exactly going to be sky high.
Cheers,
SS
Try over on www.avforums.com those lads really know their stuff.
But generally you look for a PJ with high lumens(brightness) and low contrast,it of course depends on the size of room you are putting it into and how big the screen is likely to be, bigger the screen the brighter the PJ needs to be.
