- 26 Dec 2005
- Paisley
Does anyone know what these come bundled with, do you get any games/freebies?
hmm i see they r 5 i stock :]Ulfhedjinn said:It's probably the typical bundle of card, manual, driver disc and cables.
If you're thinking of the one I'm thinking of, it's also sold out now and on pre-order again.
dbmzk1 said:Google is friendly you know.
http://www.leadtek.com/uk/3d_graphic/overview.asp?lineid=1&pronameid=313
Comes with:
Power DVD 7.0
Trackmania Nations - Special Edition
SpellForce2
HDTV Cable
DVI-to-VGA Adaptor
6-pin Power Cable
Theres 2 in stock and I'm really considering buying one myself. Absolute bargain at that price!
That is correct, my card had all those things in the box. (I do think that the HDTV cable is a S-Video one though but not sure)dbmzk1 said:Google is friendly you know.
Comes with:
Power DVD 7.0
SpellForce2
HDTV Cable
DVI-to-VGA Adaptor
6-pin Power Cable
Reality|Bites said:Is that the one for £214 inc vat?
You probably get 2 games with it as always, The last Leadtek card I owned was the FX5900, I got Big Mutha Truckers and Gunmetal with it.
same here damn that city link man where is heshrek2 said:I should be getting mine in a couple of hours![]()
bbspeed said:
InwardSinging said:In stock and £20 cheaper available elsewhere though.
