So I've just began leak testing my loop. Should I run the pump at full bore for the duration of the test? It's an EK-XRES 140 REVO D5 PWM (connected via molex only so it runs at 100%).
I have filled my res about halfway... is that correct?
I am running the test with plain distilled, so when I come to drain that and put in my coolant, I'm a bit concerned about getting every last drop out. How important is that? I do have a drain valve at lowest point. I will be using Mayhems X1 Clear Blue UV.
