leaking flat concrete roof
17 Jul 2008
Southampton
so I wonder has any one got any experience in using
ACRYPOL or isoflex liquid rubber as a sealer for a flat roof?
I'm finding it hard to choose between the two,
Flexacryl Roof Repair Compound and Isoflex Liquid Rubber is very good, personally I would only rely on this as a temporary fix to get you through the winter, save up for something that will last such as a EPDM Rubber Membrane.
Acrypol & Isoflex are only a temporary fixes, ideally you need a complete new roof covering.
But, Isoflex is better in my opinion.
The concrete roof on my workshop sprung another leak last month, the felt was beyond repair, I had it replaced with fiberglass roofing.
And the front bay window concrete roof also had a leak, solved that with a tin of liquid roofing which had fibreglass strands in it, but the name eludes me at the moment.
You can buy a 10mtr square fibreglass roofing kit for about £120, maybe less if you shop around.
I did consider epdm, very good product,but the rough condition of my concrete roof, I decided on fibreglass was better.
Sounds like Flexacryl - I used it to seal a leaky garage roof a few years ago, did a very good job too.
thanks! do you think it could be laid direct to the concrete slab, or wiser to lay some plywood first then rubber on top ?
Yeah the bonding adhesive works with wood, concrete, and metal. Just make sure the area is clear of debris and smooth so that the adhesive can bond to the rubber properly.
Thanks Brozart, I hadn't previously considered EPDM as I assumed it was too expensive, but that isn't bad.
How would you go about sealing this to an existing brick wall?
ahh my flat roofs a bit bobbly so maybe a plywood sheet first would be best
Same here, I just used my grinder to take off the high spots first, no need to use ply.
Unlikely it would have been a issue using fibre glass, as us you can work in the matting, but I prefer not to find out the hard way, & having problems later.
