Glue another gate valve on to the end, they're £15 on ebay.Hi so even in the off posistion water comes through the valve
this is for a pond filter
I noticed that the pipe work attached to the valve is glued on
i was thinking i could possibily put some type of end cap on the valve?
any other options to stop the water?
CorrectOk i think u mean buy just one gate valve
Then glue it on the end
So i end up with two gate valves and hopefully the 2nd one will work
Correct
Floplast Solvent Cement to glue it on, £5.40 at Screwfix
It's probably leaking due to crud built up in it stopping it closing properly. Take it off and give it a good clean. Might solve the problem without replacing anything.
Dirtwhat did u mean by crud buildup btw?
Could you add a bit of pipe and a screw cap end so you can drain it when needed.
Dirt
Enough to stop the valve from closing/sealing.
There’s a compression joint where the black pipe goes into the grey/white section.
Measure the external diameter of the place pipe and get a new ball valve (as suggested above) to suit, a short length of the same diameter pipe and some suitable PVC pipe cement.
Loads of examples here:
https://www.ebay.co.uk/b/Pvc-Ball-Valve-in-Ball-Valves/184117/bn_7022840809
Some are threaded, some are compression fit and some just glue onto the pipe. You just need to measure the OF of the black pipe.
Any big garden/pond centre store or agricultural supplier should have the parts you need.
As far as im aware its 40mm you probably measure the outside diameterI will look at it again I'm guessing u mean dirt buildup on the bottom or something
yer i was thinking about something like this: https://www.screwfix.com/p/mcalpine-t23u-multifit-blanking-plug-white-40mm/96079 but that pipe I got is 43mm and this is 40mm so im not sure it will work.
If you completely want to blank it off, take the whole section off at the compression fitting near the filter and replace it with a blanking plug.
https://www.screwfix.com/p/floplast...OKZS0Aom_mtVWQSgyCIaAt0VEALw_wcB&gclsrc=aw.ds
