- 4 Dec 2009
- Worcestershire
I set up my loop with all barbs etc not leaking and I installed a new pump top of which I am 100% was securely fitted (as I double checked) however, after about 10 minutes of having the system on I realised there was water everywhere!!!! No damage luckily but on inspecting the pump (Laing DDC) the water seems to have come through the PCB area but didn't go through the O-ring. RMA time? Or is there an easy fix for this?
Thanks
Thanks
