Caporegime
- 13 May 2003
- Warwickshire
Hi all
Volvo S80 and water trickles down the inside of the windscreen in heavy rain.
I've called my insurers and they're saying that since it's not actually damaged, they won't cover it with the £75 excess replacement and I'll need to do it privately.
I called a couple of windscreen places and they said that since the glass often cracks when removed, they won't be able to do a remove and refit, it'll have to be a full replacement job at ~£300.
Does anyone have any tips for other things I can try to sort out a leaky windscreen? It's coming in from the top right. Are they correct that these screens cannot be removed and re-fitted / re-bonded?
Cheers.
Cheers.
