Learning Python - some advice please
27 Feb 2004
Kent
Hello, I am new to Python (3) and Raspberry pi 4. in the lockdown I have bought 1 for me and 1 for my (geographically distant) grandson and have bought some miniature LED traffic lights kits. I am going to try to help him learn.
I have programmed (in a very simple way) 3 x LEDs to switch the Red / Amber / Green lights in their correct sequence for 1 set of LEDs connected to the PIOI.
from gpiozero import LED
from time import sleep
#to identify pins used
ledred = LED(21)
ledamber = LED(20)
ledgreen = LED(16)
while True:
#1st traffic light
ledred.on()
sleep(9)
ledamber.on()
sleep(2)
ledred.off()
ledamber.off()
ledgreen.on()
sleep(5)
ledgreen.off()
ledamber.on()
sleep(2)
ledamber.off()
Actual code lines are indented correctly. What I need to do now is to add code to operate another set of lights so that when the first set are on red the other set are on green, etc. i.e., coordinated as a real pair of traffic lights!
Not sure how I do this - e.g as subroutines? do they even exist in Python!
General guidance would be welcome. Thanks, Mel
what I would do is create 2 functions, one for turning from go to stop and the other from stop to go, both functions can take a traffic_ligh_name so it knows which one to act on.
Then, you need to create 2 variables, these are to hold the current status of each traffic light.
Then use a time function to wait and just loop through them.
so if light_1 is go you know light_2 should be stop.
then loop
wait x seconds, move light_1 to stop, wait y seconds, set light_2 to go etc
Edit: if you're on Facebook check out the Python Programming Language, i'm one of the admins on there and it's more active than Python Programming Society which is our other group which is mainly for beginners but appears to be dying slowly.
Thanks for the guidance, "AHarvey" - tidying up a bookshelf of "collected items" (i.e. junk in the eyes of the other member of the household. When I have done that (after lunch) will turn my attention to Python.
Will also check out Facebook - which I am a reluctant member of!
Mel
Once you've got it working as you'd like, maybe you could try writing something that sends data to each other so only one of yours is on green while all of his are red etc :D
this type of problem is a good example of a state machine.
google for traffic light state chart or state machine images.
i was suprised by how many different examples this throws up.
