First of, has anyone had any dealing with BT leased lines, specifically 10meg on a 30Meg bearer?
Any problems with service and support?
Second, the Router they are going to supply is a Cisco 1841 which i believe only has 2 LAN ports (one WAN/one LAN??). I need to connect 3 servers directly to the internet, and this leaves me with a problem.
With only one or possibly 2 LAN ports, how can I connect the third server?
Would it be OK to just uplink a switch to the Cisco router and then wire the 3 servers into the switch?
I am pretty sure this will be OK,and want to canvas opinion.
Thanks
Elliott
Thanks
Elliott
