The cushions are a bit saggy, so you wont fix that without some serious work ( re stuff them), but you can do wonders with a proper leather restoration kit if its starting to crack.
Have a look here, it take a while to do which is why pros charge so much but if you have time, you can probably transform it for about £60.
Also, you'll be surprised how much giving it a really good clean with the right fluids will change it's look, so you might not need to 'restore' it as such as the first stage of restoration is a pretty brutal clean anyway..
