there only 1.4W how bright actually are they?
Brighter than the 60 Watt halogens that they replaced for sure.
It's not really fair to compare prices though at face value?!
Before it's a fair comparison you first need to divide the price of the LED lights by at LEAST 10 (Most Halogens last 5-10k hours) then you need to add into the equation how much energy is saved.
Once you have done all that LED lights are actually massively cheaper in the long run![]()
http://m.diy.com/mt/www.diy.com/nav...18960?skuId=12939666&un_jtt_redirect#features
Its actually a pack if 3
Yeah, but you have to be realistic. Paying a tenner a bulb because it lasts 25 years instead of a couple of years doesn't necessarily make sense.
I've just made those numbers up, but you need to actually see the return in a reasonable timeframe.
(Plus you're looking more like 30-40 years life with normal usage
I fail to see how they are as bright as 50W halogen when it's only a 1.4W LED
The 9W (3x3W Rotundity CREE) lights I bought are a fair comparison to a 50W halogen so unless B&Q have some magic LED's I don't know about I'm very sceptical on their true brightness![]()
Yep, I installed 12dimmable Rotundity CREE GU10's when I was doing the electrics in my rents new conservatory.
Very well built, bright and 100k life
Expensive but you get what you pay for and these badboys will no doubt out-last me! lol
These are the ones I bought: (Link embedded in photo)
http://www.ebay.co.uk/itm/GU10-MR16...ng_SM&var=&hash=item256ab2e274#ht_5516wt_1164
Excuse my ignorance but what are SMD?
but at 7.50 a bulb, these seemed to ne among the cheapest yet brightest available
Do you know what degree those bulbs spread the light over? I need some but as they are going quite high up I need them not to spread the light too much.
Errrr not really
They use cheap generic LEDs, Non-Dimmable, only 400 Luminous Flux and worse of all only 30k mtbf!
On the link I provided you can get proper Rotundity CREE LEDs, Dimmable, 480-580 Luminous Flux and 100k MTBF! All for £6.30
Shop in Hong Kong, how do you know what you are getting?
Is cree a type or a manufacturer?
I do not want dimmable, but these work fine in no dimmable transformers also do they?
Shame delivery is weeks away...
45-60 degrees
