- 19 Dec 2003
- UK
Hey folks, I am in the process of changing the house lights to be LED's, I was fortunate, you could say(!), in the fact that the previous occupants of the house decided to take the lightbulbs with them, which was nice of them...
Anyhow, most of it has been straightforward to find the LED replacements for each, the only ones I am having trouble with are G9 bulbs.
We bought 3 new light fixtures from BHS which use G9 halogens, and they are in the 3 places we use most (hall up/down & lounge) so ideally want them LED as soon as possible.
The only issue is, I have so far tried 3 different brands, the first 2 were from a well known rainforest site, 2 different brands, but both of them caused what I can only describe as a strobe type effect, in that if you wave your hands in front of you, you could see it 'strobing' or flickering, it wasn't good!
I then tried from Homebase, a set, which did not flicker or strobe, but they were 2w, so it was depressingly dingy in comparison to the 6x40w halogens it currently uses.
So the question is, does anyone have any recommendations for G9 LED bulbs that do not cause that strobe effect and have a comparable light output to the 40w halogens? They do not need to be dimmable, I did see on LedHut they have 5w G9's which I was tempted to try, but it's expensive if they have the same issue (albeit the light will be better for sure)
