led connectors
30 Jun 2007
can anyone help with thease connectors. they are for led's on the case of my pc. there is 3 34 pin connectors in total which branch off back to the led light connector and have numbers on them.does anyone know what i connect the 34 pin leads to as theres no where on the mb and there is 3 of them aswell.
img.php
[/URL].
img.php
[/URL].
What case and motherboard (make and model) are you using?
Never seen connectors for a case front like that before.
Errr . . . No idea. Its not a connector ive even seen before? Whats the case? There must be for some sort of controller that may have come with the case? 2nd hand? Or brand new?
it is a alienware case i bought from the outlet store brand new. they are rgb led's thats all i know.do you know if i could cut the connector off and use the white blue green and red wires some other way to connect.
I'm betting the Alienware case is made for Alienware motherboards.
Personally, I'd take it back and get a refund - then buy a real case.
