LED controller
NZXT Hue comes with a 2 meter strip, but you need a free 5.25" bay. You could alternatively get the Bitfenix Hydra which allows you to control the LEDs on the Bitfenix Fans - it may also work with their LED strips, but I've not tested it!
BTW, the link you've added doesn't work.
Could try the LED mod instead for like £20 less? Has a remote control to control them, and is a 5 metre strip as well!
Yeah the LED mods a good way to go, I got mine and made a dc jack to molex connector, you get a 5 metre strip, which was enough to do two cases and have some left over. You also get a little remote control for it which is cool, mine cost me £15. If you've got any questions just ask me ive done it twice lol, Id be glad to help out.
