I've spent the last couple of hours planning where to put some LED downlights in 2 rooms. They are both quite small rooms so I'm going with 4x in each. I had to shift my calculations a few times due to the joists which ran pretty much bang on where I wanted to put them. Because the rooms are fairly small (2.7m x 2.4m) I'm a bit restricted by where I can place them without them being too close to the walls or too close to the middle.
What's the thinking regarding the distance the downlight can be from a joist? The closest would be around 25 - 30mm away from the joist. As LED's don't give out too much heat, is this acceptable?
