LED fans
I think you will have to remove the bulbs as some of these LED's are powered simply by the movement of the fan rather than through the molex/cable. I can hold the fan up in front of a big room fan and the force will make the lights go on from there.
What?????? No, they wont be. Running a electric motor without powering it, ie by pushing the spindle around will generate power. However when an electric motor is consuming power to move the blades, it will not generate power.
Unless we have something here that defies the laws of physics
pack up that hydrogen fuel cell the worlds power reqirements are solved
On a serious note, you shouildn't need to take it apart, just get a pair of small side cut pliers and cut the wires (usually not even insulated) as they run to the LEDs. You might even only need to cut one as they are often wired in series.
