Ello all..
Not sure where to start.. fitting some led's as replacement indicators on a bike, only the front indicators though..
So..
However i know this will send the indicator into an absoloute mental disco fit, so.... if the original bulb draws 20watts/1.5amps(ish)@~14volts am i right in thinking that 10.7Ω of resistance would fix that problem? say if it were between the end of the array and the earth line?
Does that seem about right or a load of rubbish?
So..
Solution 0: 7 x 2 array uses 14 LEDs exactly
+----|>|----|>|----|>|----|>|----|>|----|>|----|>|---/\/\/----+ R = 56 ohms
The wizard says: In solution 0:
* each 56 ohm resistor dissipates 22.4 mW
* the wizard says the color code for 56 is green blue black
* the wizard thinks 1/4W resistors are fine for your application
* together, all resistors dissipate 44.8 mW
* together, the diodes dissipate 560 mW
* total power dissipated by the array is 604.8 mW
* the array draws current of 40 mA from the source.
