LED Indicators
1 Dec 2005
So I bought some LED indicators off ebay to replace my huge OEM ones while I put on a tail tidy and although they look great I realise now that they suck in the daylight, has anyone bought some that actually work in the sunshine? I know I could get much more expensive ones, like say R&G ones which cost 5 to 10x more but would they even be visible in direct sunlight?
Any advice is appreciated.
That's each. They're not cheap but they're loads better quality than pretty much all others (with the exception of Rizoma perhaps)
It's the > £100 each mirrors that get me :eek: At least with indicators there is something to perform better once you sling a bit more money at them.
I bought a set of Rizomas, and tbh, they still look awesome - you can really tell the difference even from the cheaper knock offs :D.
24 quid for 1 indicator? lol
I've probably wasted hundreds on pounds on cheap indicators over the years. They all end up getting wet inside and all fail so nowadays I spend the £24 for nice bright, reliable indicators and I've had no problems since.
Ah ok, they're slightly different to the Speed Triple ones (I bought the Triumph ones recently which are spot on).
I'll be keeping that link for future though :)
