led strip lights etc for RC
11 Oct 2005
Derbyshire
hi, does anyone have any knowledge of any good led strip lights of lights thereselves to fit onto a rc plane.
thinking of putting some on a rc plane that i have, but not sure about what voltage they need etc, or what works, or what is worth buying that you can visibly see.
maybe someone out there can help?
thanks
Led strips generally work off 12v so if your using a 3s lipo then your good to go if using a 4s then youl need a 12v regulator
When i added some to my hexacopter i just bought a couple of roles off ebay for a fiver
