Hi,
I'm not sure if this is the correct place to post this but thought I'd post here as I think you guys will know the answer
I had some cheap pound store 5 LED lights that plug into a USB port.
I have two side by side wall mounted Dell U2412M monitors and I plugged one of these into each monitors rear USB ports and it looked really nice. Posted a picture here a while back
Problem is I usually just use one monitor, so when I had them both on, it looked odd as the LEDs on the strip used more often were dimmer and more 'used'
I was wondering if I could get some LED strips (similar to the ones I have in my case) from the internet and connect a USB connector to them somehow?
I bought and cut up a molex connector for my in case ones and soldered the wires to that ... Is there a similar way to do this with a USB connector?
Also how would it work as the strips would be 12v and USB doesn't provide that surely?
I am trying to DIY something like these Antec ones
Would they (the ones I make) suffer the same issue where one would become dimmer if used more often? Or were the pound store ones just really cheap?
Thanks!
Thanks!
