LED Torch
nam
nam
18 Oct 2002
London
Hi All,
Does anyone have a micro LED torch. Could you recommend which manufacturer i should get please ?
Thanks
You mean a little thing you put on a keyring? Or a proper torch?
Ive got one of the mini ones and it was £3.99, made by energizer and its really bright.
a proper torch similar to this ... LED
Nother recommendation for petzl ones.
Although, if you just want something to put on a keyring something like these on ebay are great, surprisingly bright and last a decent amount of time.
Arc AAA Premium - best everyday carry torch you'll find. Not cheap though.
http://www.arcflashlight.com/arc-aaa.shtml
I've had one for about 18 months - still in perfect condition, still on original battery and it makes my old Maglite Solitaire (or indeed, a non-LED AA Maglite look feeble).
http://www.flashlightreviews.com/reviews/arc_aaa-p.htm
Flashlightreviews.com said:
If you are looking for a light which could be considered simply the very best keychain light that will likely last you a lifetime, the Arc AAA should be at the top of your list.
i have a pal light and its just obscenely good, always on so u can find it and even though its always on the battery still lasts 2 years and it has sos mode, low beam and high beam and also a small cone for signalingy, its coated in rubber and is INVINCIBLE as well as water proof, runs of a 9v battery and is about the same is size as one
Get a hong Kong made one of the bay..
I've got one and it's very good.
It's got a strong aluminium body, stupidly bright led's, it's water proof, battery will last days if left on and it cost about £5 including postage (and that was over 2years ago)..
nam said:
Just found the Lenser V9 under £7. :)
I've had 4 of these - they all broke within days. But they cost less than a pound here, so wasn't too bothered about it. I won't be buying any more though, they're just too feebly built.
I also bought an aluminium 9-LED torch from Hong Kong (when I was living in UK), similar to the previous poster, and it's very solid. Also extremely bright, but it isn't very focussed. It lights up the whole room amazingly well, but doesn't produce the spot light effect my old maglight used to.
