LED TV backlighting
9 Mar 2006
London
I am looking at colour changing LED backlights for my 49" curved Samsung 4K TV can anyone recommend me a good brand? one issue I have is with it being on a stand not mounted the stand is bracketed at the bottom of the tv so I would need the bottom strip 170mm from the bottom would this make much a difference? as it is a nice size screen, also the flexible connections that come with them for aligning your next strip I am not sure if they would be long enough to reach the connection for the bottom strip.
Thank you
I got a set of Tingkam® Waterproof 5M 5050 SMD RGB Led Strips from the rainforest. As long as they are not dirt cheap Chinese ones unless you want to replace the dodgy power adaptors. Works from a remote and have them running around the back of my tv using some angled connectors and extensions. They are quite bright ones so i tend to set them on the lowest brightness.
Sounds the same as what I have, I used little strips of double sided 3M tape to secure
