LED up my PC case
22 May 2017
Hello all!!! I have a Phanteks Enthoo Luxe case and a ASUS Formula VIII motherboard. Now I am wanting to connect up my case LED and also purchase a LED strip to light up my case and I am wondering can they both be connected via a y splitter to the AURA header on my PC motherboard? Also Could I connect case fans via the splitter to the Aura header on my motherboard or would I need to purchase a control center with the case fans? Its just that I would like them to sync up so if anyone could help I would be extremely grateful.
Many Thanks
Martin Dean
The splitter will definitely work for LED's and you should be fine with hooking up many LED strips to one header. You only really run into problems once you get to around 3 meters of LED strips, which is unlikely.
The RGB case fans I have, have a separate RGB header which can be attached to the splitter and then a standard fan header which can be plugged into a fan header on the motherboard. (You can get splitters for the fan headers on your motherboard too)
