Left 4 Dead system requirements
12 Jun 2007
Ireland
heads up
OS: Windows Vista, XP or 2000
CPU: 3.0 GHz P4, Dual Core 2.0 or AMD64X2 (or higher)
RAM: 1 GB for XP / 2GB for Vista
Optical Drive: DVD-ROM Drive
HD: At least 7.5 GB of free space
Graphics: Direct X 9 compatible video card (Video card must be 256 MB or more and should be a DirectX 9-compatible with support for pixel shader 2.0)
Audio: Direct X9.0c compatible sound card
source: http://www.fudzilla.com/index.php?option=com_content&task=view&id=9641&Itemid=1
Specs are pretty good for people i know with lower spec computers.
Might see if my mates laptop can run this when its out and try and convince him to get it.
still think it is weird how they hardly ever state GPU chips on these. What the hell has the amount of RAM got to do with it? The card I currently have installed at he moment has 512Mb ram. I built a PC for my mates Father in law the other day for browsing on the internet and the card I bought had 512Mb ram.
Difference? Mine was £200 the one I bought for the PC build - £30.
Really wtf has RAM got to do with it? They should quote some GPU's
I don't think any of the 3400 series will play it at anywhere near a decent frame rate and quality - they all have 256 or above and are DX10+.
