Left hander, need software for key re-mapping.
8 Oct 2008
Hull, East Yorkshire
W - P
A - L
S - ;
D - '
R - I
E - O
Q - [
CTRL - ENTER
TAB - ALT GR
Any software that can map these for left handed gaming? I found sharpkeys but you have to log off and that's tedious when you are taking it in turns with a right hander.
W - P
A - L
S - ;
D - '
R - I
E - O
Q - [
CTRL - ENTER
TAB - ALT GR
Fellow lefthander here, I found it easier to learn right handed unfort when it comes to PC gaming :(
Aye, I'm a lefty wasder-er. Just have to shift my keyboard to the right when playing.
Sometimes have to remap the odd button if the game is silly (Crouch set to C :confused:)
(I realise this is of no help to the OP! :()
I use this at work for my Mac keyboard on my PC. As it's the non numpad edition keyboard, I use the free program (which I think limits you to only 3 key changes or something) to convert f12 to delete and f11 to print screen and it works brilliantly :)
I'm a lefty who uses the mouse with my right hand and I never understood the Crouch is C thing. It's so awkward. Ctrl is so much more convenient!
I thought all us lefties used the arrow keys and little finger on numpad 0,1,2,etc for all the main keys, works really well for me. numpad 0 is run, numpad 1 is crouch etc
I'm a lefty, but use mouse in right hand and wasd/arrow keys depending on the game.
We're a weird bunch - in that we play in so many different ways that isn't natural to most people.:p
AutoHotKey
This, for each rebind you just put:
q::e
This means pressing q will send e. you can even turn this sort of thing on and off with a bit more scripting. If you have ever done any type of coding you can learn it inside 10 minutes. I use the "take over the desk and use wasd with my right hand" method. And ctrl IS crouch.
