- 10 Nov 2006
Was wondering if anyone has this game or can offer any assistance as to why the framerate is so poor.
The other half loves the lego games, and none of them have caused any issues, but this one is a PITA
My spec is in my sig.
With all gfx settings within the game turned on, the framerate will sit at 60 for a while (v-sync on), them plummet for minutes on end. If we stand still on screen for a while, the fame rate catches up and everything is fine again. This will repeat regularly causing immense frustration. Even in scenes where very little is going on, I can replicate the issue. So I tried turning things off, lowering screen res, low rate textures etc. Believe it or not, the more I turn off, the worse it gets. It wont even stay at a stable 60 with all settings on lowest and an 800 X 600 screen res
I dual boot and have tried both XP & Windows7 and got the same issues.
Just to check, I had a quick blast on GRID, then F1-2010, and can run both of those at a solid 60fps no problem with my settings.
Anyone any suggestions?
If It makes any difference, the game Is a digital download from the main high street retailer.
