Lend a hand with my first build :)
24 Jul 2010
Cheshire
I am thinking about building my first PC and currently in the process of saving for it, originally had a budget of £400-£500 but decided save for longer and now its closer to £600. this is the current system i have planned out, just wondering if you could take a look, say any faults/issues etc and maybe reccomend parts that would be cheaper and do the same/similar job as current parts.
Money is an issue here so the closer to £500 the better.
Any help would be much appreciated :)
Current idea: http://img412.imageshack.us/img412/9387/15386426.jpg
Edit: i will be using a 32" LG LCD T.V. for a monitor full 1080P. And it will be for mainly gaming on new fps's
I think its a good spec, the only thing i would change on that is the GPU to a GTX 470 but that would increase the cost.
The 460 is a very good card and should out run the 5770, i would like other people to comment on it before buying though as i might be wrong.
thanks for the help the the GPU, was wondering if swapping the corsair ram for OCZ would do the same job and shave a bit off the price?
