There's a few reviews floating around, the general consensus is that it's a very good panel if you can bear the tiny dot pitch. It's also wide-gamut so porper calibration is a must (as it is with any high-quality display).
I was considering one of these before i bought my HZ24w.
What finally put me off was the small dot pitch. 1900 x 1200 on a 22" screen equates to some tiny text. You could allways use font scaling ( vista doesn`t do a too bad job but XP`s scaling is Pants )
From what I remember the input lag wasnt too bad either 40ms or so.
But as philjohn has aready said its also a wide gamut display and it will need calibrating properly. There`s a few people complaining about over saturated reds and greens even after the display is switched to sRGB internally.
hehe, I was thinking of one before I went for the HZ24WS as well, the wife vetoed it as being far too ugly however (which it is), and even gave me permission to shell out for an Apple Cinema Display until I showed her the Hazro
