Lenovo Legion 7i Cooling setup.
24 Dec 2004
Telford
There has been a lot of talk about the Vapour chamber setup in the Legion 7i. Some reviews have stated it’s vapour chamber on GPU or CPU only and not both. I disassembled mine today and as you can see by the pics the vapour chamber covers both cpu and GPU with a couple of added heat pipes too feed the side vents. I have the i7 10875 with RTX 2070. It might be the 6 core CPU’s that only have a single vapour chamber and maybe why I get better cooling performance. It’s definitely one of the best setups I have seen and is very effective the stock paste was also applied very well and the correct amount too. I like that the fans also draw air through the keyboard and vents above each side of the power button too. The 2070 is a big chip especially for a laptop......
Pics below showing the internals and cooling system for those interested or that have asked.
Recently purchased this laptop with the same spec as well
So far i really enjoy the quality of it. Screen is probably the best bit
