- 25 Jun 2005
I have a Canon 700D, it doesn't get a crazy amount of use, but I do want to use it more.
I have the standard 18-55 kit lens and the 50mm 1.8mm lens.
The camera is used indoors only, no people are in my photographs, just objects - largely hi-fi, electronics and gadgets. Sometimes rooms are not great light wise and I want to keep things natural, so no flash ideally.
I have a half decent tripod and I typically use that with a timer and get pretty decent shots
But - if I wanted to get better quality photographs how much money would I need to spend on a new lens?
Difficult to measure by how much I want them to be better I guess, but can you buy for example a better 18-55 lens? That lens is fine for me from a focal point of view, but if I could find one that worked better in lower light condition or simply enabled better shots I'd be happy. I don't mind looking at used.
The 50mm lens takes good shots but a lot of the time I simply can't it use due to lack space to get in the right angle etc.
I don't want to replace the camera.
Any pointers?
Any pointers?
