Lens advice
23 May 2006
Blythe
I was browsing around the local photo shops today in town after a wide ish angle angle lens, I saw a sigma 17-35mm f2.8/4 EX DG HSM ASP for 79.99, that to me looked like a good price, I havent had a go at the lens but I'll need to go back in on monday if I decide to buy it as I'm transferring my money from paypal.
has anyone here got this lens? is that a good price? is it a good lens?
cheers
I'll be sticking it on a D50
if its for a cropped sensor bosy - the en a 10-20mm or equiv. is your best bet
What he means is that a 17-35mm lens won't be amazingly wide on a DSLR with a smaller sensor as the reduced size means the focal length is multiplied. On a D50 you're going to effectively increase the focal length by 1.5x so your 17-35mm becomes a 25.5-52.5mm lens.
Having said that, only you'll know if the lenses reach will meet your needs. 25.5mm might be perfectly wide enough for your needs. As for the lens itself, I can't offer you any advice as I don't know much about Sigma stuff. Just wanted to try and clarify what 33L said. Or at least what I think he's trying to say.
sorry I dont understand :S
He means if you have a DX format camera (which you do) then a Sigma 10-20mm lens is probably your best bet in terms of wide angle :)
The 17-35mm is OK but is more of a general purpose lens than a true wideangle – you should be looking at around 10-12mm minimum focal length for true wideangle.
ah right I understand, I've only got one lens at the moment and it goes to 28mm, I only want to spend around 100 pounds I know thats not much for glass and something wide but any suggestions would be appreciated
thanks
collisster
that lens doesnt get many great reviews (if any)
FM has it at 6.1/10 and the aspherical one at 5.1/10
i say go for the sigma 10-20 i have been looking at this for a while and as soon as i get the money its mine lol
another one the shop had on sale was a 17-10 mm sigma f2.8/4.5 dc same price
I think they meant the 17-70 that i have! its a good walkabout! i do struggle at wide ends with it though but the macro functionality makes up for it some what.
