Lens cleaning
20 Oct 2002
Nottingham
One of my lens after Goodwood has a small mark on the lens. Looks like water was dried on the lens but giving it a wipe doesn't shift it.
Any tips?
Shot blasting should do the trick. Failing that isopropyl alcohol or methanol on a soft cotton bud in little circles should take most things off. You did have a UV filter on there to protect it though?
nail varnish remover?
