Lens for astro photography
1 Feb 2009
So I love taking pictures of the night sky, currently been using a mix of my 50mm, pancake and 18-300 to get a range of different pictures, however I would really like a lens that will let me zoom in on the moon or planets when they become visible.
Is it worth getting another lens, or should I look to get a telescope with a mount for my 100d?
Another lens would be a good starting point and would over some versatility if you wanted to shoot other things with it, however if you get really into astro the telescope and mount are inevitable so you may want to jump the step of buying a long lens.
What length lens would you recommend as a mid point? not sure why I typed 18-300 ealier, but its the 70mm-300mm I have already.
as long as you can afford, there are some affordable 600mm options from Tamron and Sigma out there at the moment and I'm sure the web will have a wealth of comments about using them for astro work
Hi there
I've spent way too much money on 500 /600 mm lenses and teleconverters over the years and never really got the image quality I was chasing, even when using my D800.
I ended up biting the bullet and buying a 2nd hand 9" SCT Telescope from eBay with the various camera adapters and am just starting to explore that.
I would also forget about trying to do any planetary stuff with your lenses, they're just not long enough.
The difference is like chalk and cheese using the scope compared to a standard lens. Right tool for the job.
Hope this helps.
I have to agree with Pooh, if your looking for anything more than photographing the Moon then you will need a Telescope, its a far better tool for the job, and with a few accessories the majority of Telescopes you can mount your DSLR to the back of them.
If your happy with shooting the moon though, then something like this is possible with a 600mm
halloween-moon-2015 by Geoff Moore, on Flickr
Shot from my bedroom window.
