Lens for zoom? - Canon 1100D
18 Nov 2012
Hi,
Got a Canon 1100D, with the kit supplied IS lens. Issue here is that it doesn't zoom in too far, for example I was at the tennis last week and didn't magnify as I wanted it to do so, what lens would be better? Canon's 75-300mm? That retails for around £120, have up to £180 max really.
Also, how much of an improvement will it really make?
Thanks in advance.
Presumably your kit is 18-55... So yes, something that goes to 300mm will be a huge difference, plus on a crop sensor camera such as yours, it effectively is 480mm.
Sounds good, whats your opinion of the lens I listed, the Mk3 75-300mm. Is the IS on the 70-300mm worth the rather extra price, circa £320 in comparison to the £120 75-300mm regular Canon lens.
Cheers
I'm using the 55-250 IS on my 450D.
It seems reasonable, but I have nothing to compare it to so I'm probably not the best person to ask. I've managed take some sharp shots from canoes. Whether or not I could have done with a none IS lens is debatable...
avoid the 75-300mm it is a bit of a dog, the smart money these days is going either on the canon 55-250mm IS or the Tamron 70-300mm VC hand holding on a long lens IS/VC/OS is a real bonus even more so than on your short kit lens.
