Lens issue.
30 Dec 2009
Wigan Lancs
I have just bought a used Nikon 18-70 f/3.5-4.5 G IF ED and was wondering if anyone else has one. This one has quite a bit of lateral free play in the barrel sections when they are extended and rattles a bit too.
Now i have been offered a replacement or full refund so i will go for a replacement.
Having said the above it does work without fault and image quality at both ends is good.
I am just a bit concerned that i might have a bad one.
Thanks.
Here is a photo i took with it.
Sounds like you've make the right choice with getting a replacement.
Mine shows none of what you describe and I bought it used, great choice though I couldn't see me being without mine now.
Thanks for that. I will get a replacement and hope that is OK and will post a reply when i get it.
