Lens Upgrade For 450d
18 Oct 2002
Devon
I recently bought a 450d packaged with the 18-55 kit lens and the 55-250 IS lens.
I mostly photograph wildlife, birds and aircraft so the longer lens is usually the one attached to the camera, though at some point I would like to experiment with landscapes, still lifes & macro's (insects / animals / flowers).
The main problem I have with the 55-250 IS is that whilst it is capable of some great shots the auto-focus is fairly slow for tracking fast moving birds in flight (I regularly go to bird of prey displays) and even with fairly static subjects it's at most 80% reliable in the best of conditions. I would also appreciate some additional focal length as often with wildlife 250mm is not nearly enough. I haven't really made enough use of the 18-55 to form an opinion of it yet.
My budget is always going to be limited, but rather than regret buying a cheaper alternatives I'd rather wait until I could afford something I'd be happy with.
My first purchase will obviously need to replace the 55-250 and make up for it's shortcommings. I have read a recent comparison review in PhotoPlus magazine and it seems like the Sigma 120-400 lens is a good price/performance bet over the Canon 100-400, however I don't know how much better the image quality and auto-focus would be over what I have, or whether it would be better in the long run to pay twice the price for the Canon lens. Also as I'm lacking a fast lens so I was wandering (though it would be a more expensive option) whether the Sigma 70-200 2.8 and a Sigma 2x teleconverter would be a better bet in the long run than the 120-400, but I'm not sure how this combination would compare with the 120-400 lens in terms of quality and focusing?
I'd also appreciate any suggestions as to another lens that I could look at that might let me combine Macro, landscape and still life, or is this too much to expect from a single lens?
What do you guys think?
If you can get the 100-400mm I would go for that as the Canon has much better image quality, however I am sure you would be very happy with the Sigma 120-400mm or 150-500mm. The Canon has 2 stop IS vs the 4 stop OS of the Sigmas, focussing speed is supossedly comparable.
If you won't use the Sigma 70-200mm much without a 2x TC then I would ignore this option, AF accuracy and speed will be decreased along with image quality, which would be lower than the above lenses.
For a landscape/macro lens I would look at the Sigma 18-50mm f/2.8 or the 17-70mm f/2.8-4.5, both are good lenses. The 17-70mm has the better close focus with a reproduction ratio of 1:2.3 vs 1:3 with the 18-50mm, though the 18-50mm has HSM and is a constant f/2.8.
Either would be a good upgrade to the kit lens, though if you really want to do macro I'm sure you will eventually end up with a dedicated macro lens. The two lenses above are not very close to "true macro" which is considered to be 1:1, you will most likely find that you can't get as close as you want to. The kit lens is fine for landscapes and if you really want a better lens for macro I would suggest keeping that and getting a Tamron 90mm or Sigma 105mm, which are both great lenses.
