- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
LEPA cases will be arriving next week. These offer a a good quality case at affordable pricing. The LPC 302 is ace for high end cooling with support for up to 13 fans.
LEPA LPC 301 Gaming Tower Case - Black @ £34.99 inc VAT
LEPA's entry level gaming chassis offers a great look with a fully meshed front panel to maximise airflow with its great red LED front fan this beast with look right at home next to you when your fragging away all day and night.
- Fully meshed front panel provides super ventilation
- Dust filter for all meshed area to prevent dust accumulation
- Complete I/O interface for utmost expandability
- Tool-less design for easy installation and drive bay maintenance
- 4x thumbscrews for easy side panel access
- Effective cooling system with 4x 12cm fans included
- Dimensions: 440 x 188 x 420mm
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 6
- I/O Ports: USB2.0 x 3 / eSATA x 1 / Audio x 2
- Expansion Slots: 7
- Front Cooling: 1 x 120mm Fan
- Rear Cooling: 1 x 120mm Fan
- Side Cooling: 2 x 120mm Fans
Only £34.99 inc VAT.
ORDER NOW
LEPA LPC 302 Mass Airflow Gaming Case - Black @ £79.99 inc VAT
LEPAs new to the chassis market, but that doesn't mean there products are not excellent. The LPC 302 Case offers the ultimate in cooling performance, with support for up to 13 fans and excellent airflow. Watercooling is also supported with the case too. The top mountable HDD dock adds a great finishing touch to all the features for this.
- Top 1x 3.5"/ 2.5" hot-swap dock (optional)
- 8x expansion slots to support 3-way VGA card installation
- Cable tie for advanced PSU securing
- Bottom mounted PSU slot with removable dust filter
- Rubber strips and grommets for PSU and HDD installation
- Tool-less installation for all devices
- Advanced cooling performance with up to 13 x fan capacity
- Dimensions: 520 x 221 x 450mm
- 2.5" Drive Bays: 6
- I/O Ports: USB2.0 x 4 / eSATA x 1 / Audio x 2
- Expansion Slots: 8
- Front Cooling: 3 x 120mm Fans
- Top Cooling: 2 x 140/120mm Fans (optional)
- Side Cooling: 6 x 120mm Fans (optional)
- Bottom Cooling: 1 x 140/120mm Fan (optional)
Only £79.99 inc VAT.
ORDER NOW
LEPA LPC 303 Midi Tower Case - Black @ £29.99 inc VAT
LEPA are a newcomer to the computing market, but they are designed a great range of new cases. The LPC 303 offers cable management and a bottom mounted PSU layout to ensure your system runs quiet and cool.
- Fully meshed front panel for maximum airflow
- Interior black coating makes stylish and elegant looks
- Bottom mounted PSU slot with anti-vibration rubber stands
- Thumbscrews for easy side panel access
- Cable management design for neat cable routing
- Cutout for quick CPU cooler maintenance
- Advanced cooling system for up to 6 fans capacity
- Front : 1x12cm LED fan included
- Top : 2x12cm fan (Optional)
- Side : 2x12cm fan (Optional)
- Rear : 1x12cm fan included
- Dimensions: 495 x 180 x 431mm
- 3.5" Drive bays: 5
- 5.25" Drive bays: 4
- I/O Panel: 2 x USB2.0 / 2 x Audio
Only £29.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
