PERFORMANCE
Most likely the same image quality or slightly better than the D200.
Identical materials and robustness to the D70.
MichaelG said:Am I right in think Nikon is brining out a new AF-S 70-300mm VR lens in October?
It looks like Nikon are bringing out a new 70-300 VR but don't hold your breath for when it will be available. The new 18-200 VR has been out for many months but it's impossible to find one in stock anywhere.MichaelG said:Am I right in think Nikon is brining out a new AF-S 70-300mm VR lens in October?
Is there much difference in performance between SD and CF cards ?nolimit said:not happy with SD format only, body and materials used looks like same as D70.
Yes, but it's only f5.6 @ 300mmSDK^ said:It looks like Nikon are bringing out a new 70-300 VR but don't hold your breath for when it will be available. The new 18-200 VR has been out for many months but it's impossible to find one in stock anywhere.
What did you expect - It only costs £400 !?!?!Gareth said:Yes, but it's only f5.6 @ 300mm![]()
It's fine by me and this lens is only 725g including VR!Gareth said:Yes, but it's only f5.6 @ 300mm![]()
bigredshark said:High flash sync was one big d70 advantage in some situations, though to the average user it wasn't a big deal and it was out of place on such a low end camera. my bet is they're getting rid of it to differentiate towards high flash sync speed on the D3 series when they get here and possibly the upgrade to the D200
