- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
All I'm going to say is 530w of stable, true reliable power for under £40.
Nothing more is required.
BeQuiet Pure Power L7 530W '80 Plus' Power Supply @ £39.98 inc VAT
Need a power supply that will smooth your path onto the web, securely and reliably? A unit that will handle standard office and graphic programs without a problem, and is always ready for a little gaming here and there as well?
If so, then PURE POWER is the right choice for everything you'll need from your computer – stabile, cost-saving operation (80PLUS). And because the be quiet! name is behind these units, you'll probably barely even realise they're there. Efficiency and reliability was never more affordable!
- Classic office and web applications
- Standard graphics applications
- Basic gaming
- 120 mm quality fan.
- The RPMs on the fan are automatically governed based on the temperature
- 80PLUS certification. The high efficiency of up to 87% reduces power dissipation (waste heat) and also saves power.
- Fulfils the requirements of the environmental and energy-savings Energy Star 4.0 * guidelines
- Low power consumption in stand-by mode (<0.5 W).
- Fulfils the EuP guidelines
- Various connection options, with up to 15 connectors
- 2 years manufacturer's guarantee
Was £45.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
- Basic gaming
Was £45.99 Inc. VAT
ORDER NOW
