Lets talk zoom
28 Mar 2005
Hi guys,
I'm going to be purchasing one zoom lens this year. This will be used for F1 photography with my 5d.
I think I'm leaning towards the 100-400mm 4.5/5.6 theres obviously a fairly big difference in price between the mk1 and mk2 of this lens. Has anyone compared the 2 ? is there a big difference?
Is there any others i should be considering. I guess somewhere around the £1000 is where I'm looking.
From what I've read the mkii is a significant improvement both in terms of picture quality and usability if you didn't get on with the previous lenses push pull system. That doesn't make the old one suddenly a bad lens if your budget won't stretch to the mkii the original lens is still a fantastic piece of glass and I for one prefers the push pull zoom!
I've been looking at the Canon 100-400mkii and also the Sigma 150-600 sport and I cant make my mind up which one to go for.
I'm very tempted by the sigma. Just want to ensure there is a significant difference relative to the tamron.
Th Dina is line disrobed than be canon at 400mm.
My feelings pretty much echo what a1ex2001 said.
The Mkii will without doubt be a better lens but the original is still a fine piece of kit. I'm also a fan of the push pull zoom design which I find quick and accurate.
I've had a 70-200 F4L and a 300 F4L prime in the past. Whilst it could never quite beat the 300 for focus speed or outright IQ (unsurprisingly!) it wasn't a million miles away. It did however soundly beat the 70-200 in both focus speed and IQ so really is a quality item.
Have run it on the end of a 30D, 1D MkIIN and currently the MkIII in my sig. It also manages quite well on a Kenko Pro 1.4x TC. Focus speed is down (it may not even focus on a 5D) but IQ remains virtually unchanged which is good!
The early reviews show only a slight bumb in sharpness, thst isn't a bad thing since the old was good. This means the mk1 is worthy when purchased 2nd hand considering value for money.
Another option is the Tamron 150-600mm, half the piece of the sigma 150-600 and almost as good. It is also going to be sharper than the Canon 100-400m at 400mm. If you think k you might need more reach then it is worth a.good look IMO.
There's two versions of that Sigma 150-600mm isn't there? Sport and non sport so it's worth clarifying which one you guys are considering :)
From memory the non sport is F6.3 or something at the long end? Cba looking it up!
They have the same aperture. The Contemporary version doesn't exist yet.
both lenses are f/5 on the wide and f/6.3 on the tele end, at 400mm it is f/5.6 I believe and the same as the Canon.
They still haven't released that other one? For some reason I thought the sport one had a faster aperture... You know, for sports! Guess not >.>
Just checked the specs and it the only differences seem to be weight, size, minimum focus distance and image quality I guess!
The Canon 100-400mm will definitely be more portable and I'm not sure you'd need the 400mm-600mm end more than the 100mm-150mm you'd get from the Canon but I guess that's for the OP to decide.
The Tamron 150-600mm took Sigma by surprise. I imagien they were planning on releasing only the sport version but then when Tamron released a similar spec lens that was smaller, lighter and half the price sigma had to create the C version out of thin air.
The Sigma 150-600 S is definitely a big and heavy lens, not hand holdable.
Whther the long end or the short end is more important depends entirely on the OP's uses. FOr F1 then 400-600mm likely isn't that useful but for wildlife it is critical IMO.
thanks for all the input guys. I might pop down the shop and have ago with the sigma and tamron alternatives. I have 4 weeks off work so really want to get stuck into playing around with some new kit :D
