Leveling / smoothing a concrete to concrete join?
19 Dec 2003
UK
Hey folks, we recently had a small area of the driveway concreted, and where it meets the existing, there is a slight raise (the older concrete being slightly higher). Its about 2cm, no more.
Ideally it would be flush or just 'smoothed' for a rounder profile, is that possible to do? Any recommendations? I did think about angle grinding but that could be a bit O.T.T ?
It's the sort of thing in a house you would use a threshold to solve, but outside is a little different.
Thanks in advance! :)
is ether side level ?, on 1st glance it looks like a separate strip added to the new/low side after shuttering was removed. if you can chip the new bit/low side edge down to 5 to 6 inch wide and deep then poor fresh concrete and smooth with a float between the two sides
