lexa blackline few questions
30 Nov 2007
i have a quick question about the blakline case
at the bottom of the case there is a place to add a 80mm fan.
would you be used and an exhaust or intake ( im thinking intake
also
ive just bought 2 x 180mm akasa red led fans and 2 x 80mm akasa red led fans ( 2 x 180 to replace the nzxt ones )
i also have a xilence fan controller 3 x 3 pin and one for the led brightness
being as the fan cables are not long enough to reach to the controller i have used one of the adaptors provided to lengthen the cable. now am i right in joining these cables that require 4 pin molex to 3 pin in the order of matching the red and black wires together and then joining connectors ?
reason i ask
1. im not clued up at all with electics
2. it maybe paranoia or i may smell that funny electrical smell lol sorry i hope you know what i mean
any advice would be truly gratefull
all fans are working and leds are on etc etc, if i had done anything wrong certain elements would work im taking it as ? am i corerect ?
