Lexmark X1190 Printer Sharing
26 Sep 2007
Amsterdam
Trying to set up printer sharing, my PC sees the printer just fine but then you have to verify the model and make of the printer. My printer (Lexmark X1190) isn't listed and when I click have disk I put the disk in but it says it can't find the compatible software or something. I'm running XP 64 bit.
I imagen that its because on the disk there isnt any XP 64 drivers, you tried downloading a x64 set from lexmark? - i take it the printer is pluged into a xp32 computer?
Yeah the printer is plugged into an XP 32bit computer. I've tried downloading Server 2003 and XP 32bit drivers from Lexmark to no avail. Should I try Vista x64?
