Hi all,
I have a Lexmark X4975ve.
Its pretty decent, but 1 annoying problem. When using the ADF to scan A4 documents the resulting PDF is the correct width but it adds a massive white blank space underneath my document. What id like is to use the ADF to scan multiple docs so someone else can print it all off on A4.
Atm i have to manually scan opening the cover each time. Pain in the back side when your doing it 30 times.
