I'm looking for a 5v RGB Fan controller that
1. Works with 3pin 5v Fans
2. Allows 6 Fans to be connected
3. Custom software to control fans
Anyone know of any?
XSPC Do a good one but the output is 5v so a bit pointless as I'd still need an addressable connection on the motherboard to connect the lot up, it really just seems to be a hub splitter.
Unless is some cable that goes from a 3pin 5v to a motherboard USB or normal USB connection?
Anyone know of any?
