Hey,
I've been spoiled in the past with Asus's Fan xpert 2 software, I especially liked how you were able to tell it to turn the fans off until you reached a certain temp.
Now that I've moved to a x79 sabertooth, it doesn't seem to be compatible with fan xpert 2 and probably never will by the sounds of it, So I'm stuck with the mediocre fan expert 1. It's got me searching for an alternative method to have the fans turn off when below a certain temp, not having much luck though.
Anyone know of a fan controller that does this? It needs to be able to interface with the mobo and pull temps from there(I don't want to be messing about with probes). Can be single slot bay or standalone box (Like the nzxt grid)
I also tried speedfan but it doesn;t pick up all the fan headers and the cpu sensor fails and shows 128c, seems that's the only software based controller available.
