- 12 Jan 2006
As title says, i am looking for a gigabit switch to replace my hub as i rescently started streaming video over the network and it is fast becoming a choke point when the other pc's are busy on the network.
Minimum ports are 6, the main issue is that it needs to be quiet (why i chose a hub in the first place)
All the devices bar the 360 (which is 10/100) are gigabit enabled and i have cat5e/6 already in place when i did the wiring (newer links cat 6, older ones mostly the ones going through floors are cat 5e)
I dont need anything fancy such as vlan's, firewalls and such which you get on a cisco
My current setup:
Red: used for video streaming+high bandwidth apps
Black: normal use
Lightning: wireless
Thanks in advance
My current setup:
Black: normal use
Lightning: wireless
Thanks in advance
