LF Someone with a Lian Li PC-Q08...
20 Jun 2013
Hi,
Could you please measure from the rearmost edge of the top fan mounting to the rear of the ODD cage and let me know if there will be sufficient room to mod this into a 200mm fan mount? My google-fu isn't turning up anything.
Thanks!
it may be a aqueeze with some modifications neeed. Whats the thickness of the 200mm fan your wanting to put in?
Will measure when I get home
I hadn't thought about thickness... It's a plan-in-progress, so any suggestions are welcome. Was looking at making it a positive pressure enclosure to vent exclusively out of the rear of the case. A high pressure 200mm intake on the "roof", 120mm / 140mm in the front seems ideal.
What PSU are you guys using for these? I can see from reviews that there are issues retaining the 4 bay 3.5" enclosure with longer power supplies which would defeat the object of this case for me. Would need to be able to run an i5-4670k and GTX 760 both at stock, 3xHDD, 1xSSD, 1xODD. Cheers!
