(seriously it doesn't take much to run at all, very efficient program really)
Edit Found it:- The minimum recommended spec is 1GHz with a recent graphics card, but it may run on lower spec PCs than that, so try it and see. AMD Athlon XP 1600+/256MB+ DDR/GPU with hardware vertex shading support is barely adequate for full LFS experience, any slower than that and you're going to have FPS problems with fullfield online races and more than 8 AI-players.
Hmm good question. I just checked the LFS site and I can't find a definitive minimum or recommended spec.
I did find a thread on the LFS forum about LFS rigs and a spec me an LFS PC thread. Those ought to give you some idea of the specs people are running for LFS.
This site, http://lfsbench.iron.eu.org/?c=completemax, seems to be where people benchmark their PCs for LFS. I've only just found it today looking for spec info for you.
Personally I run a 3700, Epox 9NPA Ultra, 2Gb Corsair RAM, 1x74Gb Raptor, 1x250 WD SATA2 HDD and an x1800 512Mb gfx card and LFS looks damn good and fast with that spec.
