LG 25UM58-P resolution issue.
24 Nov 2016
Hey guys, hoping there is a simple fix for this otherwise it's time for a new card and this one isn't that old...
My GPU has 4 ports, 1 HDMI, 1 DVI-I, 1 DVI-D and 1 displayport.
I purchased 2 of the above monitors and when purchasing was advised to use 1 HDMI cable and 1 DVI-HDMI converter. The issue here is that the monitor connected via DVI-HDMI is capped at 1920x1080 when it is supposed to be 2560x1080.
Would a displayport-HDMI 4k converter provide me the resolution I need?
TIA,
Brad.
Hiya
as the 25UM58 has only 2 x HDMI, I would suggest getting a DP to HDMI cable/converter, then you can connect one screen via HDMI-HDMI, and the second DP-HDMI
this will then remove the max res issue of DVI
Dan
Hiya
Dan
Hi Dan, thanks for the reply.
I note that 'most' DP-HDMI converters are limited to 1920x1080 on the box too which still does not solve the issue I would assume.
Any knowledge of these 4K converters?
Brad.
